Hi all;
I’m using docker in rootless context since few day , I uselly use docker by adding my user in docker group or as root as most of people , ans
I’m trying to run the casaos script install , allmost is ok exept one step:
--- Made by IceWhale with YOU ---
[ OK ] Your hardware architecture is : aarch64
[ OK ] Your System is : Linux
[ OK ] Your Linux Distribution is : debian
[ OK ] Memory capacity check passed.
[ OK ] Disk capacity check passed.
[ INFO ] Updating package manager...
[ OK ] Update package manager complete.
Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
If I want to check the status docker.service , I’m doing this:
systemctl --user status docker.service
● docker.service - Docker Application Container Engine (Rootless)
Loaded: loaded (/home/ordinatous/.config/systemd/user/docker.service; enabled; preset: enabled)
Active: active (running) since Sat 2024-01-06 08:24:32 GMT; 1h 45min ago
Docs: https://docs.docker.com/go/rootless/
Main PID: 13965 (rootlesskit)
Tasks: 35
Memory: 77.0M
CPU: 4.706s
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/docker.service
├─13965 rootlesskit --net=slirp4netns --mtu=65520 --slirp4netns-sandbox=auto --slirp4netns-seccomp=auto --disable-host-loopback --port-driver=bu>
├─13976 /proc/self/exe --net=slirp4netns --mtu=65520 --slirp4netns-sandbox=auto --slirp4netns-seccomp=auto --disable-host-loopback --port-driver>
├─13998 slirp4netns --mtu 65520 -r 3 --disable-host-loopback --enable-sandbox --enable-seccomp 13976 tap0
├─14005 dockerd
└─14021 containerd --config /run/user/1000/docker/containerd/containerd.toml
Does somebody know if I can change something in the script ?
Thanks !
