Hello.
Though I’ve searched for the answer to using both NIC ports to use each on a separate network, I must have missed it. How does one configure the original Zimaboard with CasaOS to use two networks? Thank you.
Gary
Hello.
Gary
Do you want to use two network ports for aggregation to get double the access speed?
No. I need to have my Zimaboard to exist on two separate networks at the same time.
Thank you.
Thanks for your info.
Hey, we are interested in your user story.
What do you want to achieve specifically through existing on two separate networks?
Actually, if you install ZimaOS on your ZimaBoard, you can have access to it anywhere with Internet access if you turn on the remote access.
Look forward to your reply.
