USB3 external hard drives as an Raid 1 System
Hello,
I’m a complete beginner and have installed Zima OS on a mini PC. Unfortunately, it only supports two internal hard drives. However, I’ve connected two 1 TB external USB hard drives. I’d like to set up a RAID 1 system, but unfortunately that doesn’t work. I’m also missing a Linux client. As soon as these features become available, I’ll purchase the paid version right away.
Or are there ways to make this work right now?
I think the system is brilliant as a home server. Finally free from US online storage.
Thank you very much for this
Uli
Can you expand on what you mean with “But unfortunatley that doesn’t work”? Do you get any specific errors?
I haven’t tried my self yet but I’ll try out now at the same time.
Edit:
Well, I plugged in two usb-drives, they show up on the dashboard but when I press “manage”, nothing shows up - is it the same for you?
After some searching the forum, seems like USB drives aren’t supported yet..
Hello,
Thank you for the quick response.
Access to the USB hard drives is possible even from an external device, at least on Windows. I’ll make do with some synchronization software.
Is an official Linux client planned?
I’ve only had the system for a week, but so far I’m thrilled with how easy it was to set up and share files externally using ZimaOs.
Thank you very much for that.
  1. We will support creating RAID using USB in the next version, and we hope you will be able to experience it.
  2. Our amazing community developers recently created a Linux client, and we hope you can try it out and give us some feedback. GitHub - astralcynsm/ZimaClient-Linux: a small network management tool based on ZeroTier, Wails and Samba · GitHub
Ok, i will try the Linux client and wait for the next version.
Thanks very much
I’m running 1.6.0 beta and can confirm that usb drives are usable as “regular drives” now - no issues over the past few days - fingers crossed :slight_smile:
What do you mean “ usable as “regular drives” now”? Ist it now possible to make a Raid 1 with two USB Drives?
That’s exactly what I mean by it :slight_smile:
I setup a raid1 on two USB drives no problem
ok, i also update to 1.6.0 Beta. Setup raid1 is still in progress.:slightly_smiling_face:
It’s been working pretty well on Windows so far, but on Linux Mint, I can access all the hard drives via their IP addresses in the browser—though unfortunately not at the file level. The Zima client is installed, but unfortunately I can’t get it to open. The Zima client won’t start, and there’s no error message. Too bad—I was actually hoping to move away from U.S. products.
Hello! Can you please confirm what HDD USB enclosure you’ve used? One for each external HDD, or one which houses both (or more than 2) HDDs?
Thanks a lot!
Thanks a lot! :slight_smile:
I can give you guys also another way for Raid1 with external drives :wink: I just have bought this enclosure which can work natively as a raid0 or raid1. It’s visible in ZimaOS and works like a charm althought there are a few reports that say about sudden malfunction with disk breakage. It stops me from getting serious data to these disk so far. I’m testing it with less important data.
Hello,
I have connected two different USB enclosures: one from Intensio and one from Inatec.
