Update Monitor for ZimaOS – Docker Update Monitoring, Automatic Updates, Backups & Restore
Hi everyone,
I would like to introduce my Update Monitor for ZimaOS.
The project started because I wanted a more detailed and reliable way to monitor updates for my Docker applications. Over time, it has grown into a much larger tool with update detection, automatic update policies, backups, encryption, restore functions and much more.
The application is still under development, but many important functions are already working.
Main Features
Update Monitor scans the installed Docker applications and displays their current update status.
It can show for example:
  • Current
  • New version available
  • Docker image update available
  • Pinned version / digest
  • Local image
  • Detection errors
The application also shows information such as:
  • Installed version
  • Available version
  • Local image digest
  • Remote digest
  • Container
  • Docker image
  • Ports
  • Current container state
  • Project/source link
GitHub, Codeberg and other project sources can be detected where possible.
[Screenshot – Main Update Monitor overview]
Reliable Update Verification
After an update, Update Monitor does not simply assume that the installation was successful.
The update process is divided into separate phases:
Backup → Installation → Verification
After installing an update, only the affected application is checked again.
This means an automatic update cycle works approximately like this:
App 1 → Backup → Update → Verify App 1 → App 2 → Backup → Update → Verify App 2
It does not start a complete scan of every Docker application after each individual update.
Update Policies
Each Docker application can have its own update policy.
Available options include:
  • Fixed version
  • Upgrade policy
  • Follow updates
  • Notification only
  • Automatic updates
Automatic updates can also be scheduled individually by weekday and time.
There is also an immediate update option if the application should be updated as soon as an update is detected.
[Screenshot – Automatic Update settings]
Backup Before Updates
Before installing an update, Update Monitor can automatically create a backup.
Two backup types are available:
Quick Backup
Stores the information required to restore the previous Docker configuration/image state.
Full Backup
Additionally backs up the application data.
Backups are stored outside the Update Monitor AppData directory, for example:
/DATA/Backups/Update-Monitor/
Each application receives its own backup directory.
This is important because the backups remain available even if Update Monitor itself or another application is uninstalled.
Backups currently have a retention period of 5 days.
[Screenshot – Backup information inside application details]
Backup Encryption
Backups can optionally be encrypted.
Encryption currently uses:
AES-256-GCM
The backup password itself is not stored.
When encryption is enabled, the Compose configuration and application data are packaged and encrypted into a file such as:
payload.umbackup.enc
Instead of leaving the application data directly readable inside the backup directory.
The interface shows whether backup encryption is:
  • Disabled
  • Active and unlocked
  • Active and locked
The password can also be changed later.
[Screenshot – Backup Encryption settings]
Backup Restore
Available backups can be displayed directly from the application details.
The restore dialog shows information including:
  • Backup creation time
  • Backup type
  • Number of containers
  • Encryption status
  • Remaining retention time
A selected backup can then be restored directly through Update Monitor.
For a full backup, the application data is restored as well.
After the restore, Update Monitor performs another targeted verification of the affected Docker application.
[Screenshot – Restore Backup dialog]
Port Conflict Detection
Update Monitor can detect when different Docker applications use the same published port.
If a conflict is detected, a warning appears at the top of the interface.
Opening the warning shows:
  • The affected port
  • The applications using it
  • The corresponding containers
This makes it easier to find Docker configuration conflicts.
Project Source Detection
Update Monitor tries to determine the original project/source behind a Docker image.
The long-term system is designed to use several sources instead of relying only on GitHub.
Detection can use Docker/OCI labels such as:
  • org.opencontainers.image.source
  • org.opencontainers.image.url
  • org.opencontainers.image.documentation
  • org.label-schema.vcs-url
This allows the application to provide direct links to GitHub, Codeberg and other project pages when available.
GitHub API Support
A GitHub token can optionally be configured.
Without authentication, GitHub API requests are limited.
With a token, Update Monitor can use the higher authenticated API limit.
The interface displays:
  • GitHub connection status
  • API requests already used
  • API request limit
The token can be tested and removed directly from the settings.
Responsive Interface
The interface is designed to adapt to different screen sizes rather than relying on fixed device lists.
I am testing it on:
  • Desktop
  • Tablet
  • iPad
  • Smartphone
  • Portrait mode
  • Landscape mode
The application details can be expanded directly inside each Docker card.
Status indicators use different colors so that the current state can be recognized quickly.
Current Status
The project is still actively being developed.
My main goal is to create a Docker update system for ZimaOS that is:
  • Reliable
  • Easy to understand
  • Safe
  • Transparent
  • Suitable for both manual and automatic updates
The backup and restore system is especially important to me because an automatic update should not simply replace a working application without providing a way back.
There are still features and improvements planned for future versions.
Update Monitor is also intended to become part of a larger Monitor Suite, together with my existing Disk Monitor and potentially additional monitoring tools later.
Update Monitor – Current Development Status
Since my last update, quite a lot has changed again. Update Monitor is becoming much more robust and is gradually turning into more than just a simple update checker.
The update logic has been heavily revised. Manual and automatic updates are now coordinated in a controlled sequence. While an update check is running, Docker changing actions are blocked. The same rule also works in the opposite direction: while an update, restore, uninstall, image source change, or another Docker operation is running, no normal 1 / 6 / 12 / 24 hour update check can start.
After an update, Update Monitor now verifies only the affected application instead of scanning the complete Docker environment again.
Another major change is a persistent scan cache. When Update Monitor restarts, the previous scan results are loaded immediately. It then performs a fast local Docker comparison first, without contacting GitHub, Docker Hub, GHCR, or other registries.
If nothing has changed locally and the configured scan interval has not expired, no unnecessary full update check is started. If only one application has changed, only that application is checked. A newly detected stack can still trigger a full discovery scan when required.
A larger new feature is Image Source. Update Monitor can inspect Docker images and look for alternative image sources, for example Docker Hub and GHCR. For stacks containing multiple images, every image is handled separately, so the user can decide exactly which image source should be changed.
Image sources use a simple compatibility system:
  • Green: compatible or verified source
  • Yellow: switching is possible, but with a warning
  • Red: known incompatibility, switching is blocked
Before changing an image source, Update Monitor creates a backup. The process then goes through Compose validation, image pull, container switching, verification, and rollback if something fails. Progress is now shown directly during the operation, for example Backup, Pulling image, Switching container, Verifying, and Complete.
Testing real image source changes also exposed some interesting Docker/ZimaOS edge cases. For example, ZimaOS may already store a new GHCR image reference in the Compose configuration while Docker still reports the previous registry name in Config.Image.
Update Monitor now treats the image source stored in the ZimaOS Compose configuration as the canonical source for Compose applications. Docker Config.Image is used mainly as runtime information and as a fallback.
Digest verification was also improved. If Docker Hub and GHCR provide exactly the same build and digest, an old registry name reported by Docker is no longer automatically treated as a failed source switch.
Safety checks around image changes have also been expanded. After switching, Update Monitor verifies that the container is actually stable. Restart loops, increasing Docker restart counts, failed health checks, incorrect digests, or other startup problems can trigger an automatic rollback to the previous Compose/image source.
The UI has also received several improvements. The top summary area is now more dynamic when additional states such as errors or port conflicts appear. The different sections inside the application details also use clearer color separation:
Blue = Image Source
Yellow = Backup
Red = Uninstall / critical actions
The idea is that users should be able to recognize the different functional areas immediately without having to read every label first.
There have also been many smaller improvements to dialogs, scrollbars, progress indicators, backup settings, search, sorting, update policies, responsive layouts, and general Docker state handling.
The project is still under active development. The latest real world tests with image source switching have uncovered several issues that would have been difficult to notice during simple testing. That is exactly why I am testing these functions intensively before releasing Update Monitor publicly.
