Unauthorized error on qbittorent
Anybody had the same issue when running qbittorent and will just display Unauthorized on the web gui? Kindly share your resolution. TIA
You can try opening the privacy browser and see if you can log in properly.
really sorry I am new to this function. Would you mind explaining further? thanks
I have the same issue. I tried it in a private window from Firefox as @pgear suggested and it also worked correctly the first time there. If I close that tab in the private window and open qBittorrent again, I get the same ā€œUnauthorizedā€ error.
With that knowledge it seems to be an issue with how qBittorrent is storing cookies on my device. This seems like a bug, but there might be a workaround if we don’t allow the browser to store cookies for that specific site. This wouldn’t be preferable as I’d need to do it on each of my devices, but I’ll do some testing and report back.
Scratch that. Changing my browser settings to not allow storage or cookies from the url of qBittorrent did nothing. In fact, if I close all private windows and restart my computer, it still gives me the unauthorized error if I open qBittorrent in a new private window. There’s probably something happening on the server end, but I’m totally stumped as to what it might be.
I am also having the same issue and do no know what to do. Tried asking from the group but still did not get any answer
I just came across the same problem. Simply adding http:// in front of the IP worked for me.
Thanks xocavod. That got me onto the qbittorent webui login page.
but here I stumble at the next hurdle - I’m quite a noob - I can’t log in.
I tried the ā€œadminā€ and empty password, my login and password for the nas I want to run qbittorent on. ā€œadminā€ with my password. , and some variations on those. In the zimaos tips when clicking on ā€œopen qbittorentā€™ā€ is says for password ’ get from log’ I assumed that would be my password as I don’t know what log or where to find that (download?)log.
edit: I found the log, but in the log i do not find a password. ???
Click on Settings-General-Web based terminal.
Enter the following;
docker logs qbittorrent
You will see in the logs something like:
The WebUI administrator username is: admin
The WebUI administrator password was not set. A temporary password is provided for this session:
Now you can go to URL: http://localhost:8080 and log on using details provided in container logs.
Go to Tools - Options - WebUI - change the user and password and tick ā€˜bypass authentication for clients on localhost’ .
Hey, first time using a Zima or any home server. I try what you sugest, however the terminal return: ā€œWARNING: Error loading config file: open /DATA/.docker/config.json: permission denied
permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get ā€œhttp://%2Fvar%2Frun%2Fdocker.sock/v1.47/containers/qbittorrent/jsonā€: dial unix /var/run/docker.sock: connect: permission deniedā€
I have no ideia of what to do.
