Ubiquiti Unifi Controller with local LAN IP instead of Docker IP possible?
Hi All,
I am new to ZimaBoard and trying to test a couple of Docker Containers and want to retire my Synology. On that Syno I have the Unifi Controller running from jacobalberty. The container runs stable and in “HOST” mode. From my understanding, my Unifi Application has a local LAN IP address and not a docker container one beginning with 172.xxxx
Now I tried to setup the Image (Unifi Network Application) from the ZimaOS AppStore from LinuxServer.io
I tried so many different options and settings, but when I set Network to “Host” I am not able get the Unifi Controller up and running. When I set it to “Bridge” it starts up fine, I can go through the wizard and can see the app with the local IP address of my Docker Container 172.xxxx
But I want my Unifi Application running with local LAN IP address like 192.168.xxxxxx
On your Synology this works fine (maybe because of a different image), but on ZimaOS I can’t get it running. Maybe there is an issue with the Mongo DB that comes with that package, maybe it’s a Layer 8 issue.
Hope you guys can help me out here :slight_smile:
Thank you,
sportklotz33
