Why do we need to reset CMOS?
Resetting CMOS is actually restoring BIOS settings to the factory default state, which can solve many problems caused by incorrect configuration, damaged settings, or hardware changes. It is a relatively safe and simple troubleshooting method, usually as the first step in solving complex system problems.
Specific steps
Step 1 Turn off the computer power
Turn off the computer and disconnect the power plug to ensure that the device is completely powered off.
Step2 Open the chassis
Carefully remove the case side cover to allow access to the main board.
Step 3: On the main board, find the CMOS battery
Step 4 Remove CMOS battery
Use a small non-metallic tool (such as a plastic pick) to carefully remove the battery from the retaining clip.
Step 5 Wait for a while
Wait for 5-10 minutes to ensure that the capacitor is fully discharged.
Step 6 Reinstall the CMOS battery
Return the battery to its original position to ensure correct installation.
Step7 Close the chassis
Reinstall the case side cover.
Do you have any other stories worth sharing about resetting CMOS settings? Feel free to share them here or in our Discord! We look forward to your sharing!
