Time Machine Backups?
Has anyone had any luck setting up Time Machine backups on the ZimaCube? If so, would you mind giving a walkthrough? :pray:
I have the same problem on my pcx86 ZimaOS 1.2.5-beta3. Time machine does not recognize the shared smb folders. It would be important to find a solution. Any ideas?
Hello, zimaos does not currently provide this support, but we will quickly update and add it in the next two new versions. I hope this will satisfy you. If you have any other requirements, please let me know! Thank you very much for your feedback!
TimeMachine support is absolutely vital. A server/homelab that cannot host a simple TimeMachine backup is completely useless. I’ll hang on for another update, but without APFS support this OS is worthless. I don’t want to switch back to TrueNAS, but if that lack of support for TimeMachine persists, I’m not going to have a choice.
You are absolutely right and we realize that. Therefore, we have decided to include these features in future releases. However, due to limited staff resources, this will take some time. Thank you for your patience and understanding! I’ll reply here as soon as it’s updated!
Do you have any updates on this?
I installed today zimaOS to my Blade and was surprised to read this.
Is there any ETA for this important feature?
thanks
I have had success with setting up a TimeMachine backup. You will need to setup an instance of the docker container mbentley/timemachine.
It is expected to go live within two months.
So great! We also referenced the configuration of that repository to implement TimeMachine and considered integrating it directly into the SMB configuration of ZimaOS.
Latest news: We expect to support this feature time machine in zimaos v1.3.2! A beta version is expected to be released next week!
x.com If you are interested, can I invite you to join the test in advance?
If it’s possible I would like to join the test
OK, I can invite you to join the closed beta channel. Please join discord firstļ½žIceWhale
Release 1.3.2-beta1 Ā· IceWhaleTech/ZimaOS Ā· GitHub Hello, this feature has been added to the latest zimaos v1.3.2 test version. Welcome to experience and test it in advance.
I also tested the Time Machine for my macOS, and it must be said that it absolutely doesn’t work, there are a lot of things that it doesn’t work on this system.
It would be time to accelerate development.
You can’t just send copies to influencers and YouTubers and make your real customers wait to take their concerns into account.
Thanks for sharing your feedback — we really take user experience seriously.
Could you record a short screen video showing how Time Machine behaves on your setup and where it fails?
That would help us understand the issue better and investigate it more quickly.
Here are some screenshots :
New and real ZimaOS customer here. Time Machine working great on 1.5.4 (backup creation anyway, have not tried a restore yet). And except for the known drive standby issue (which is being addressed), everything else working correctly as well, interface is entirely adequate.
I am super happy to read you, however, it does not solve my concern your message :grinning_face:
Your initial issue message indicated ZimaOS Time Machine does not work at all, the majority of the interface also fails in other areas, and that ZimaOS team only cares about influencers and not all users. I was simply pointing out that this is NOT true across the board (also note ZimaOS team already addressed the standby issue I and other non-influencers were experiencing).
The ZimaOS team has reached out to you here, and you have not yet provided the details they requested to help you with your issue. So the delay here does not appear to lie with the ZimaOS team.
