Why can’t ZimaOS directly install applications or use tools like apt? If necessary, how can I install them directly?
Find the app on github and look for the docker compose or yaml. On the ZimaOS home screen, click the + on the right above the app icons, then “Install a customised app” and then click the arrow pointing into a screen icon on the top right of the pop up for “import”. Paste the docker compose code for the app you wish to install. You might need to finish inputting some entries yourself here.
That should do the trick, although it’s a bit hit and miss if it works.
