Tailscale and ZimaCube as Exit Node
My son will be overseas this fall for several months with a windows laptop. I would like to allow him to use the ZC as an exit node.
I have successfully installed Tailscale on ZimaOS and can access it through the generated IP address. However, I can’t seem to figure out how to properly activate it as an Exit Node.
Has anyone had luck with this or offer assistance?
Thank You in Advance
kind of late but after you have your node up and running you need to access the tailscale console in zimaos and type:
tailscale up --advertise-exit-node --accept-dns=false
then to avoid container bootloops you need to add a new environment variable in the zimaos tailscale settings menu:
TS_EXTRA_ARGS = --accept-dns=false --advertise-exit-node
hey what does it look like when you add the new environment? im typing something wrong because it breaks my app then I need to reinstall everything. also when I reboot the app stops working
appreciate the help!
These instructions worked very easily but I did get this message.
Warning: UDP GRO forwarding is suboptimally configured on enp2s0, UDP forwarding throughput capability will increase with a configuration change.
See https://tailscale.com/s/ethtool-config-udp-gro
is this something I need to dig into more?
the provided link takes you here:
https://tailscale.com/docs/reference/best-practices/performance#ethtool-configuration
but I’m not sure how best to apply those configurations or if I even should since I don’t really understand them.
