"System" widget does not show custom apps
Using some “self-made” apps (via docker yaml).
In the latest version of ZimaOS 1.4.3 - they aren`t shown in the widget “System”. Only installed from the store is shown.
In the BTOP - processes are visible.
I can confirm that and also some apps from a official store doesn’t show either. This list is missing Immich.
Thank you for your feedback. We have confirmed that this is a bug and we are working on fixing it. Thank you for your support.
