I find ZimaOS to be sufficiently lightweight, but the fly in the ointment is that the Zima Client mobile app only allows read-only access to files and lacks the ability to upload content.
我觉得 Zima OS 足够的轻量化,但是美中不足的是,手机 App 操作 Zima Client 文件只能读,无法上传内容。
I hope to be able to use the native Android “Share” feature to transfer documents or file data from my phone to ZimaOS via the Zima Client.
我希望可以使用安卓上的分享功能将手机上的文档或文件数据传输通过 Zima Client 到 Zima OS 上。
BTRFS is a solid choice, but I hope to see an option to create RAID storage pools using ext4. ZFS is far too heavy and doesn’t really align with ZimaOS’s positioning as a lightweight NAS.
BTRFS 是不错的选择,但是希望可以提供 ext4 的创建 RAID 存储池,ZFS 太重了不太符合 Zima OS 的轻 NAS 地位。
Finally, I hope ZimaOS can support the NFS file-sharing protocol directly within the WebUI configuration, as it is natively supported by both Linux and macOS.
最后我希望 Zima 在 webui 配置上就支持 NFS 文件共享协议,这是 Linux 和 MacOS 都支持的。
Thanks.
