[Solved] `````zimaos_ai_intel missing
Hi team, I want to report a problem.
I will describe this problem as follows:
I’m trying to install the app zima_ai_intel instead of the regular zima_ai because I don’t have a GPU in my ZimaBoard 2 yet, but I’m getting these errors:
marcos@ZimaBoard2:~ ➜ $ sudo zpkg install zimaos_ai_intel
Password:
starting install module...
2025-09-17T19:02:36.564+0100    info    client is nil, wait to add event handler        {"event name": "module:install-progress", "func": "message_bus.(*MessageBusService).AddEventHandler", "file": "/home/runner/go/pkg/mod/github.com/!ice!whale!tech/!zima!o!s-!common@v1.5.0-alpha7/message_bus/message_bus.go", "line": 183}
2025-09-17T19:02:36.569+0100    info    Message bus connected   {"func": "message_bus.(*MessageBusService).connect.func2", "file": "/home/runner/go/pkg/mod/github.com/!ice!whale!tech/!zima!o!s-!common@v1.5.0-alpha7/message_bus/message_bus.go", "line": 97}
2025-09-17T19:02:36.570+0100    info    add event handler       {"event name": "module:install-progress", "func": "message_bus.AddEventHandler", "file": "/home/runner/go/pkg/mod/github.com/!ice!whale!tech/!zima!o!s-!common@v1.5.0-alpha7/message_bus/message_bus.go", "line": 138}
Failed to install module:  bad response code: 404
Please notice that this app is reported as part of zpkg list-remote:
marcos@ZimaBoard2:~ ➜ $ zpkg list-remote
NAME
zimaos_terminal
zimaos_firewall
undelit
zimaos_ai
zimaos_ai_intel
mobile_backup
And I can reproduce the problem like this:
Just try to run sudo zpkg install zimaos_ai_intel
And here are the specs of my machine:
Zimaboard 2 1664.
ZimaOS 1.4.3.
I’m not using the client OS, since I have a Linux machine, so I’m using SSH.
Updated to ZimaOS 1.4.4, but the problem still persists.
The team is looking into this issue, and our engineer will address it.
Hey, our engineers have already made the repairs. Would you please try it again?
Sorry, I’m still getting Failed to install module: bad response code: 404. I ran zpkg update first, but I still get the same error as before.
Please try to reboot the OS first.
Solved. I rebooted my ZimaBoard, executed zpkg update and then I could install it. Thanks.
