[Solved]NVME position not recognized
I am trying to install 4 NVMEs in my Zimacube. All 4 are recognized in position 2-4. Unfortunately none are recognized in position 1. Any suggestions on how to fix this?
Perhaps these three terminal command can help us understand why one of your nvme does not appear
  1. Enter lsblk on the command line to check whether the 4 nvme are correctly recognized.
    img_v3_02c1_39a722c7-212f-42f9-a411-4a63d58a02dg
  2. Enter lspci on the command line to find the values corresponding to the four nvme.
  3. Enter cat /etc/casaos/local-storage.conf on the command line to find the value corresponding to nvme
    img_v3_02c1_43228da7-e33f-45b8-9429-750e73cfeecg
  4. The last method requires you to turn on the check function on the browser, then open the storage management page, just like my illustration, find the request named disk, find the corresponding nvme0/1/2/3 inside, and check their index Whether it is 90/91/92/93 in sequence
No password required for initial login via command line
But you need to connect the monitor to zimacube, enter alt + f2 to switch channels, and then enter root to login before you can enter other commands.
Is your current version ZimaOS 1.2.1?
Goultron here. Here’s the same issue again.
I don’t have a wired keyboard but the web interface seems to see the drive
However, it does not show up in the bay
Also the order of the drives it does show is off, 1 of the 2TB drives is dissapeared
I am using V1.2.1
Remember it’s a weekend and support is based in China, so you may not get an answer until Monday morning China time, ie 9 am in China is around 00:00 to 01;00 UTC
ZimaOS V1.2.0 Community Feedback and Iteration Summary Hope this link can help you,We will provide a temporary solution within a week.
We will provide a temporary solution within a week. ZimaOS V 1.2.0 Question Annoucement Hope this link can help you
