[Solved] Lost samba shares
I had my samba shares working but now they no longer apper.
ZimaOs appears undernetworks in Win 11 bout nothing past that.
I copied the path from within Zima and pasted in Win still nothing happens.
jad no updates or other changes to system so its a bit odd.
a internet search suggest a windows issue losing netwoork share.
I ran the scipt in powershell and had no results.\any suggestion would ne great/
cheers
Hey, have you read this post?
Is this helpful to you?
i have one drive and its internal sata. trued all this solutions with no success. i get a The network connection could not be found.
More help is available by typing NET HELPMSG 2250.
I have some suggestions. If you can try these suggestions and record the screen operation process, it will help locate the problem:
  1. Try connecting to the ZimaOS SAMBA shares on a Mac, iPhone, or Android device.
  2. Use Zima Client to connect (download address: Download ZimaOS )
Look forward to your feedback.
Thanks, I have given up on your product. Samba sharing should not be this complicated and I can see the zima share on my windows and Linux networks but the zima server denies access. i dont have the time to be a beta tester. I expected the final version to work and it initially did, until it didn’t. This lack of reliability for me
is un satisfactory for a final product.
All the best to you and your team
G
SOLVED…
Type Regedit in the search bar and click ok.
Navigate to
HKEY_LOCAL_MACHINE >> SYSTEM >> CurrentControlSet >> Services >> LanmanWorkstation >> Parameters >>
Then right clink on a blank white space in the right window.
Select New - DWORD ( 32-bit ) Value. and name it AllowInsecureGuestAuth
( Capital every first word then hit enter.)
Now click on that file and change the value from 0 to 1.
Your done.
Thank you for your feedback. It will be valuable to more people.
