[Solved]Fresh Zima Install Appstore Problems
I am a newbie. Have never run anything other than Windows but am a fast learner. This video will explain my current predicament.
Youtube Video
when i first intalled I also had this problem, but it seem to solve it by itself. after 1 or 2 days it had update the appstore catalogue itself. I recommend you to check for updates in the settings, and try to turnoff completely and then powerback on to see if it changes.
Yes… It did in fact resolve itself. I went in did a few chores and came back after about 4 hours and the cpu was only at 3% so i checked the app store and it had resolved itself. I was able to install Immich and am now setting it up. Thanks.
I have a similar problem on Zima OS 1.5.4. When I add a third appstore like bigbearcasaos, the default one disappears. When I delete all third appstores, the default one reappears. But I can’t have the default and the third one at the same time.
