[Solved]edit logind.conf
I’m trying to modify the part of logind.conf so that when I close the notebook lid it doesn’t hibernate. The logind.conf file appears as readonly and cannot be modified!
Please, can someone help me?
Hello, for security reasons, we set the files on the system side to read-only. Of course, in order to solve your needs, please provide more information about your problem.
a. What system are you using?
b. What device do you install the system on?
Good news! For ZimaOS, we will make the files in the systemd folder editable in version 1.2.3.
Hi, I’m using zimáş zimacube 1.2.2, I did an installation of it only for media server as well as for home automation, I did it on a notebook. It turns out that I only need to modify logind.conf to be able to leave the notebook lid closed without hibernating.
thank u friend.
Yes, like said, files in the systemd folder will be editable in version 1.2.3. Thanks for you pateince.
thanks my friend.
