SMB not working properly
I installed ZimaOS on a dell optiplex 7010 and well SMB was working for a couple of days but now when I go to copy files it works for a little bit then slows down to zero bytes per second and stalls. I’m on ZimaOS 1.4.0
I’m also getting a weird issue when uploading through the file browser it will start but then quickly stop and give a network error
Hi, to make the team better help you locate the issue, please follow up and fill in the problem-report template.
To do this, just open a new post here:
https://community.zimaspace.com/new-topic?category_id=33&tags=problem-opened
Would you?
I created the issue report https://community.zimaspace.com/t/smb-not-working/5042
