I understand that it’s a beta, but 1.5.2 beta is full of incredible bugs. I need to roll back as soon as possible. How can I do this without losing data?
Sorry to hear you’re having issues.
But, that is just a very wide open comment, that the BETA is full of bugs etc.
You might get better results, if you post what issues you’re having etc.
There are many people in this community that are very knowledgeable, especially the Icewhale Team.
Thank you for your reply. I was annoyed that such an unstable beta version was released…
I will try to describe the various problems I encountered, even though the only solution for me is a rollback.
The emmc memory where I installed the operating system is always full, even though I migrated everything to an external SSD.
After restarting, the eMMC empties partially, leaving 8 GB of data that I don’t understand what it is, but then when I copy the first file to the RIDE 5 I created, the eMMC fills up again.
Zima OS is mounted on a Zima Blade Quad Core, and the CPU occasionally goes to 80 or 90% for no apparent reason.
The Wi-Fi USB key purchased from the Zima Store was no longer detected after the update. I solved the problem manually via SSH, but it was still an issue.
The share via link function is still inactive.
After updating to the beta, the Zima Connect app started displaying shared folders in Samba abnormally. They appear and disappear on Windows.
I understand the frustration, I really do.
Thanks for explaining the issues, it will just be alot easier for the pros to be able to help you out.
Unfortunately I am not the one to help you with a Zima Blade, but I am sure someone with the proper knowledge will be replying soon.
Sorry for the inconvenience. If you want to switch to the latest version you upgraded from:
I am not seeing many bugs at all. In fact in beta3 I see one fixed that I reported only a week or two after reporting it. Keep up the great work and I appreciate the quick sprints and turnaround.
