Hy,
I have used for many years OMV on my Dell Chromebox 3010.
Now I switched to ZimaOS 1.5.3 on my Chromebox, i miss the ability to see S.M.A.R.T. data for my connected 4TB WD RED HDD, how can I check the S.M.A.R.T. values on ZimaOS?
Thanks!
Hello, may I ask what specific type of USB disk you are currently using? For example, is it a USB Flash Drive, USB-SSD, or another type? Additionally, please note that the S.M.A.R.T. information display feature for external USB disks is currently in development and is expected to be completed within the next two versions. Thank you for your feedback and support!
Thanks for the answer!
I have this hdd enclosure:
And using a 4TB WD RED NAS drive. In OMV i can se the S.M.A.R.T. values, ok than i will wait for the updates!
Hello, have you any update for SMART over USB storage, I have just updated to 1.6.1 and there is still no S.M.A.R.T.?
