Recognizing PCIe Oculink Adaptor Card
Thank you for your reply. I have an GTX 750 graphics card coming in the next couple of days.
If that works in the GPU Docking Station ten the RTX 5060 is either faulty or can not draw enough power.
I will let you know the results of the above.
Many Thanks.
Gavin Baker.
Hi a short update.
So as per last email,I had the USB controller card in the GPU docking station.
The ZimaBoard2 loaded the Web UI and the lspci command showed the PCIe USB Controller card in the list.
So in goes the GTX 750 Graphics Card. So same thing as before the ZimaBoard2 will not even load up the Web UI.
  1. Did the PCI USB Controller card work because it use fewer PCI lanes?
  2. Is the GPU docking station faulty for full length cards, like Graphics card?
  3. So something else stop the ZimaBoard2 from loading the Web UI (unlikely)?
I am thinking of getting another docking station….
Many Thanks.
Gavin Baker.
Hi, would the following card be a suitable replacement test for the GPU docking station? Especially since the GTX 750 needs no external power source?
chenyang Cheyang Oculink SFF-8612 4X to PCIE X16 PCI-Express Adapter with ATX 24Pin Power Port for Mainboard Graphics Card.
Oculink 4x connectors are internal and external small form factor PCI-E connectors and cables optimized for the client and market.
This oculink pci-e converter enables belowing applications.
One PCIE PCI-Express 16x 4x device can be connected,The converter can be installed into the system internally through the SFF-8611/8612 oculink interface.
The converter support all standard PCI-E 16x 8x 4x card, like USB,LAN,1394,Audio,Graphics Card.
The atx power port support 12V power. Please connect the extral power for your PCI-E card if the power is insufficient. (The switch is for ATX power)
https://www.amazon.co.uk/chenyang-SFF-8612-PCI-Express-Mainboard-Graphics-Oculink-4X-PCI-X16-24Pin-Power/dp/B0BZKF4RWM/ref=sr_1_34_sspa?crid=2S0G5K25TX0P0&dib=eyJ2IjoiMSJ9.cSQChTxTUd0Q4QR8xa95TUpWRRJUBuHDzmwyjYOpUs3GjHj071QN20LucGBJIEps.EL89HiyVqQ7wtrM5G4H8mccBTkl6hwXXdoApSbKhd1M&dib_tag=se&keywords=gpu%2Bdocking%2Bstation&qid=1774965540&sprefix=gpu%2Bdocking%2Bstation%2Caps%2C373&sr=8-34-spons&xpid=cURmnQv3-pzEm&aref=WqdbpTI1S7&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGZfbmV4dA&th=1
Many Thanks.
Gavin Baker.
