Raid1 disk replacement, for greater capacity - Sostituzione dischi Raid1, per maggiore capacità
English > I’ve been following the home NAS project for a while now and have built my own NAS using a salvaged PC.
I can’t find any information on how to replace my two 500GB drives (used for other storage) and upgrade to two 4TB drives.
The 500GB drives are currently in RAID 1. How do you recommend I proceed to get two larger capacity drives?
Thanks
Italiano > È da un po’ che seguo il progetto Nas casalingo e mi sono autocostruito un nas con un PC di recupero.
Non trovo informazioni in merito a come possa sostituire i miei due dischi entrambi da 500gb (usati per il resto) e passare a due dischi da 4Tb?
Al momento i dischi da 500 GB sono in Raid1, come mi consigliate di procedere per avere due dischi di capacità maggiore?
Grazie
Good question, upgrading from 2 x 500GB (RAID1) to 2 x 4TB (RAID1) is a very common upgrade path.
Quick note (English post)
If possible, could you please repost your question in English (you can paste the translation above)?
That way more people can help you, and it helps others later when they search the forum. Thank you
Can RAID1 be upgraded in ZimaOS?
Yes and no — it depends how your RAID1 was created in ZimaOS.
  • If it’s a standard Linux RAID1 (mdadm) then normally you can replace disks one at a time, allow rebuild, then expand.
  • But if it was created using the ZimaOS storage UI/pool, it may not support disk replacement + expansion, depending on your ZimaOS version and hardware.
So the safest advice is:
Safest method (recommended)
  1. Backup your data first (RAID is not a backup)
  2. Remove the old RAID1 / delete the pool
  3. Install the 2 new 4TB drives
  4. Create a new RAID1 with the two 4TB drives
  5. Restore your data from backup
This method always works and avoids any chance of RAID rebuild/resize issues.
If you want to check if upgrade-in-place is possible
Post the output of:
  • lsblk
  • cat /proc/mdstat
…and we can confirm whether your RAID is mdadm (upgrade possible) or ZimaOS pool (likely rebuild needed).
I ran Raid1 using ZimaOS. Since mine is currently a test bench, I could reinstall the operating system from scratch (a clean install) and connect the new 4TB HDDs. I don’t know Linux and I don’t know how to create an mdamd raid. If it’s not complicated for a Linux newbie like me, I could try. Otherwise, I use ZimaOS’s pool. I hope that in the future, when the 4TB Raid1 is full, I won’t have to go crazy trying to increase the capacity.
Grazie
Hi MicheleF, thanks for the update mate
And yes, if this is still a test bench, doing a clean reinstall + new 4TB pool is actually the safest and easiest path. That’s a really smart approach.
Your options (newbie-friendly)
Option A (Recommended): Clean install + create new ZimaOS pool
Since you don’t know Linux/mdadm yet, I’d stick with this:
  1. Backup anything important
  2. Fresh install ZimaOS
  3. Install the 2 x 4TB drives
  4. Create a new RAID1 pool using the ZimaOS storage UI
This is the easiest and most reliable way for beginners.
Option B: mdadm RAID1 (possible, but not required)
Yes, mdadm RAID1 is possible, but honestly don’t force yourself into it yet.
ZimaOS is designed so users don’t have to manage mdadm manually, and the ZimaOS pool option is the right choice for most people.
About future upgrades (when 4TB becomes full)
This is the important part:
Right now, ZimaOS RAID/pool expansion and “replace disks to grow RAID1” is not always guaranteed (depends on ZimaOS version and storage implementation).
So the best mindset is:
  • RAID1 gives redundancy
  • But upgrades later may still require:
    • backup
    • rebuild pool with larger drives
    • restore data
That’s normal even on many NAS systems.
The best protection: keep a proper backup strategy (USB or cloud).
Short best practice plan (so you never “go crazy” later :grinning_face_with_smiling_eyes:)
1) Keep OS separate from data
  • Install ZimaOS on a small SSD/NVMe (even 128GB is fine)
  • Use your RAID1 pool only for storage/data
This avoids the OS drive filling up and breaking updates/apps.
2) Keep AppData / Docker on a non-RAID disk (if possible)
If you run lots of apps/containers:
  • Put AppData/Docker on a dedicated SSD
  • Keep the RAID1 pool mainly for media/files/backups
This makes performance much better and makes recovery easy.
3) Always have 1 external backup
RAID is not backup.
  • USB HDD, another NAS, or cloud backup
  • Even a small backup is better than none
4) Plan upgrades early
When you reach about 70-80% storage full, start planning the next upgrade.
That gives you time to migrate safely without stress.
I just finished increasing the size og my 500GB RAID-1 to 1TB. Here are the steps I used:
  1. Power down ZimaOS and replace the first drive with a larger disk
  2. Power up and use the “recovery” button in the GUI to start the rebuild on the new drive.
  3. Wait for recovery to complete.
  4. Power down the ZimaOS and replace the second drive with a larger disk.
  5. Power up and use the “recovery” button in the GUI to start the rebuild on the new drive.
  6. Wait for recovery to complete.
  7. Run the command in a ssh session, “sudo mdadm --grow /dev/md0 --size=max”
  8. The command “sudo mdadm --detail /dev/md0” will verify that the RAID volume has grown to the size of the new disks.
  9. RAID-1 volume will go into auto-recovery (rebuild) state again, wait for it to complete.
  10. Run the command “sudo btrfs filesystem resize max /your_file_system_name_here”
    Storage, System in the GUI interface, and running “df” in the shell will verify the file system is the size of the new disks.
FYI, I am running ZimaOS+ v1.5.4
Thanks, but at the moment I have only used a 4-drive disk for my NAS and I use the other one as a backup using the rsync command, I thought that the raid created via software could be lost in case of OS problems, while this way I mirror my NAS disk (data) on a disk readable by any other device
