Raid zima os hd
tenho um servidor zima os a meses com um HD de 500gb e consegui um novo HD para fazer raid 1.
porem não consigo achar uma forma de fazer esse raid 1 o sistema não permite na interface web.
Google translation of your text:
I’ve had a Zima OS server for months with a 500GB hard drive, and I managed to get a new hard drive to create a RAID 1 array.
However, I can’t find a way to set up this RAID 1; the system doesn’t allow it in the web interface.
I don’t think you can simply add a second hard drive and create a RAID1 with this and your existing hard drive (meaning to keep your data on it). You most likely need a third hard drive, which serves as full backup of your content from the first hard drive (optimally you have already a proper backup in place). I assume you have to wipe your first hard drive and only then you can create a new RAID1 setup with the two hard drives.
I had a big problem a while back when an SSD went bad and I had to replace it. I managed to save the AppData, so far so good. However, the RAID 1 I set up with the 6TB storage was lost, and I had to create a folder using code to access the storage files.
Is there any way to back up the current OS image so that if the hard drive stops working, I can restore that image to another hard drive?
