Raid recovery not prompted
Hi team, I want to report a problem.
I will describe this problem as follows:
When I opened the web GUI of my ZimaBoard 2, I noticed that one of my HDDs in my RAID1 configuration was missing because it had stopped spinning. I tried to restore the RAID using a different system, but it failed.
I then bought two new HDDs, which are larger than the previous ones. However, I am unable to restore my RAID configuration in ZimaOS. When I go to Storage on the start screen and open my RAID configuration, I am not prompted with the option to recover or repair the RAID.
And I can reproduce the problem like this:
  • Open ZimaOS web interface.
  • Went to Storage → RAID1 Configuration.
  • Notice that no “Recover” or “Repair” option appears, even after rebooting.
And I have tried these operations to fix it:
I connected via SSH-Web-based-terminal and ran the following commands with help from ChatGPT:
sudo mdadm --add /dev/md0 /dev/sda (sda was new HDD)
watch cat /proc/mdstat
I waited for about 4 hours until the rebuild completed successfully.
However, after restarting the board, the issue persisted — the RAID is still degraded, and I am not prompted to restore it in the GUI.
System Information:
  • Device: ZimaBoard 2 (16 GB RAM)
  • OS Version: ZimaOS v1.4.3
  • Current Drives: 1 × 2 TB HDD (active) + 1 × 8 TB HDD (new, intended for rebuild)
In the new version, we’ve provided comprehensive RAID 1 repair instructions. Our recommendation is to upgrade your system first, then follow the system prompts to repair your array. Looking forward to your response.
Hi there, thanks for the quick reply!
I updated my ZimaBoard to ZimaOS v1.5, and now I can rebuild my RAID1 directly through the GUI.
Thanks a lot!
