After updated to zimaOS 1.8 from 1.7 my system is showing a raid failure(please check for any physical disk failure or incorrect removal). Scrutiny shows all disks passed, except my OS drive oddly enough, although it has somehow marked that drive as failed since I spun the machine up. This is a brand new setup and there is nothing in the raid. I figured I would just format the drives and rebuild the raid, but I get an error when attempting that as well. (request body has an error: doesnt match schema) Format and break attempts return with the error (failed to disable: precheck failed
I’ve had the same problem since the update. (All hard drives in the RAID 5 array are working perfectly.)
Has anyone found a solution yet, or is anyone able to help?
Thanks for your feedback. Please first run the following command in the ZimaOS terminal to collect disk-related information:
curl -fsSL https://get.casaos.io/diskinfo.sh | sudo bash
Once the command has completed, please locate the diskinfo.log file in Files on ZimaOS and send it to us.(My email: dina@icewhale.org)
In addition, could you please provide a screenshot of the relevant error? Thank you for your cooperation!
E-Mail is on the way
