Questions regarding N8N and ZimaOS
Hello,
I just received my ZimaBoard 2 and wanted to try running n8n on it. The version installed via the App Store appears to be outdated.
When I check for updates in the App Store, it doesn’t upgrade to the latest version, likely because the app listing itself is not up to date.
How can I manually update n8n to the current version on the ZimaBoard?
Thank you!
check n8n official image: n8nio/n8n - Docker Image
@Mikus please refer to the tag of the How to update dockers with 1.7? - #3 by llcool configuration container
