(I am an ordinary user, not professional operation),Could you please adjust the minimum memory of 400 MB to 380 MB in the installation script? Because the standby chip is 512 MB, but the actual memory is only 380 MB, so I want to try whether 380 MB can be installed
You can download the script and modify
readonly MINIMUM_MEMORY="400"
change the 400 to 380, then sudo bash install.sh
