PSU for zimaboard to power up two 3.5” HDDs?
Hi
The zimaboard developers initially said the board cannot power two 3,5” HDDs. Later overtime people tested and it looks like that the board does power up two 3.5”.
Is this with stock PSU or do I need to change the PSU? If I have to change, can you suggest a PSU?
Will cooling be a big problem if I don’t use hdd too much?
These are enterprise 16tb HDDs for backups.
Hi,
The stock Zimaboard PSU is 12V 3A (36W). The board itself uses around 6–10W, and each 3.5" enterprise HDD typically draws about 7–9W during normal operation. So in theory, two drives plus the board can run within 36W.
However, the main concern is the startup current spike – each HDD can briefly pull 24–30W when spinning up. If both drives start at the same time, the stock PSU may not be able to handle it, which could cause the drives to fail to spin up or the board to reboot.
If you only use the HDDs occasionally, it might still work, but for stable long-term use (especially with large 16TB drives), I’d recommend upgrading to a 12V 5A (or higher) PSU.
