Hello
I’m running into an issue with Prowlarr and Radarr integration. Although Prowlarr is configured and working fine on its own, it doesn’t seem to sync indexing services with Radarr as expected. I’ve double-checked the settings but haven’t had any luck resolving it. Here’s what I’ve tried so far:
- API Connection: Confirmed that the API key for Radarr is correct in Prowlarr.
- Sync Settings: Ensured that syncing options are enabled in Prowlarr under the Radarr settings.
- Test Connection: Tested the connection from Prowlarr to Radarr, which completes successfully.
- Manual Refresh: Tried manually refreshing the sync in Prowlarr, but it’s still not pushing indexers over to Radarr.
Has anyone else encountered this issue or found a solution? Is there perhaps a CasaOS-specific configuration I might be missing? Any advice or guidance would be greatly appreciated!
If I add indexers manually in Radarr everything works fine, so i know this is the problem
Thanks in advance for your help!
