Problem copying files from MacOS using Finder - Error 100093
Hi, i’ve got a problem with copying files through Samba on MacOS. I receive an error “The operation can’t be completed because an unexpected error occurred (error code 100093).” on both machines i tried and tested. Copying files using browser works fine.
Also, Time Machine backups are working just fine. Any idea how i can fix this?
EDIT: I can copy files directly to the machine, but not to a USB Drive that is connected. Still, copying files using browser and creating time machine backup works on that USB Drive.
P.S. I’m using ZimaOS v1.4.1-beta2 and latest MacOS with all the updates.
Hi, please provide more info about this:
[the detailed steps to reproduce the problem.]
[images and photos are better.]
[videos and screen records are best.]
And attach here the specs of your machine.
Hi i realised that my USB drive’s filesystem was ExFAT instead of EXT4. I reformatted the drive and now everything is working as it should. It must have been formatted as a ExFAT somewhere along the way when i was jumping from one OS to the other testing different homelab solutions.
I’m sticking with ZimaOS for a longer time for sure :slight_smile:
