I installed casaos on raspberry. I had to unplug the power without turning off the raspberry. Now when I connect to the server I no longer have the casaos interface but I see the apache2 page. I tried reinstalling casaos but when I connect I still see apache2. do you have a solution?
My log
Apr 17 00:00:09 raspberrypi systemd[1]: casaos.service: Scheduled restart job, restart counter is at 244.
Apr 17 00:00:09 raspberrypi systemd[1]: Stopped CasaOS Main Service.
Apr 17 00:00:09 raspberrypi systemd[1]: Starting CasaOS Main Service...
Apr 17 00:00:10 raspberrypi casaos[16532]: git commit: 36dda53e9c0cae49f52a1c58853973893540e576
Apr 17 00:00:10 raspberrypi casaos[16532]: build date: 2024-03-26T03:29:40Z
Apr 17 00:00:10 raspberrypi casaos[16532]: gateway management address file `/var/run/casaos/management.url` not found, retrying in 1 second...(10)
Apr 17 00:00:11 raspberrypi casaos[16532]: gateway management address file `/var/run/casaos/management.url` not found, retrying in 1 second...(9)
Apr 17 00:00:12 raspberrypi casaos[16532]: gateway management address file `/var/run/casaos/management.url` not found, retrying in 1 second...(8)
Apr 17 00:00:13 raspberrypi casaos[16532]: gateway management address file `/var/run/casaos/management.url` not found, retrying in 1 second...(7)
Apr 17 00:00:14 raspberrypi casaos[16532]: gateway management address file `/var/run/casaos/management.url` not found, retrying in 1 second...(6)
Apr 17 00:00:15 raspberrypi casaos[16532]: gateway management address file `/var/run/casaos/management.url` not found, retrying in 1 second...(5)
Apr 17 00:00:16 raspberrypi casaos[16532]: gateway management address file `/var/run/casaos/management.url` not found, retrying in 1 second...(4)
Apr 17 00:00:17 raspberrypi casaos[16532]: gateway management address file `/var/run/casaos/management.url` not found, retrying in 1 second...(3)
Apr 17 00:00:18 raspberrypi casaos[16532]: gateway management address file `/var/run/casaos/management.url` not found, retrying in 1 second...(2)
Apr 17 00:00:19 raspberrypi casaos[16532]: gateway management address file `/var/run/casaos/management.url` not found, retrying in 1 second...(1)
Apr 17 00:00:20 raspberrypi casaos[16532]: panic: open /var/run/casaos/management.url: no such file or directory
Apr 17 00:00:20 raspberrypi casaos[16532]: goroutine 1 [running]:
Apr 17 00:00:20 raspberrypi casaos[16532]: github.com/IceWhaleTech/CasaOS/service.NewService(0x400034a690, {0xc7e29f?, 0xf})
Apr 17 00:00:20 raspberrypi casaos[16532]: /home/runner/work/CasaOS/CasaOS/service/service.go:51 +0x314
Apr 17 00:00:20 raspberrypi casaos[16532]: main.init.0()
Apr 17 00:00:20 raspberrypi casaos[16532]: /home/runner/work/CasaOS/CasaOS/main.go:78 +0x1f0
Apr 17 00:00:20 raspberrypi systemd[1]: casaos.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Apr 17 00:00:20 raspberrypi systemd[1]: casaos.service: Failed with result 'exit-code'.
Apr 17 00:00:20 raspberrypi systemd[1]: Failed to start CasaOS Main Service.
