Hi all,
I switched to using Ubuntu instead of the pre packed ZimaOS and everything works perfectly but I was not able to find anything on how to get the light toggle switch. Wondering if anyone here was able to get some solution to turn off and on the light on power button on and OS other than ZimaOS specifically for Ubuntu but if anyone was able to get a fix on another OS that would probably be helpful too. Thank you !
