Possible bug found while Expanding RAID
Hello
I just encountered an issue while trying to expand my RAID.
I have 8 NVME SSD’s (Lexar NM790 4TB) connected to a HighPoint Rocket 1508 on a RAID 5 Array.
I just added 3 more NVME SSD’s, also 4TB each (**WD Blue SN5100 4TB)
But when I try to expand I get this message
Select a new disk at least 4.1 TB
And all the new disks are greyed out because the system says they are 4TB and not 4.1TB
Does this mean I need to only buy Lexar NM790 4TB disks to expand?
No other 4TB disk will be accepted?
Thanks for the help
I discovered the issue
The evidence shows the Rocket 1508 is reporting the Lexar drives correctly.
The incompatibility is caused by the Lexar NM790 exposing a larger namespace than the WD SN5100, despite both being marketed as 4TB SSDs.
The capacity is coming directly from the SSDs themselves:
Drive Sectors
Lexar NM790 4TB 8,001,573,552
WD SN5100 4TB 7,814,037,168
Difference 187,536,384
So each Lexar provides about 96 GB more usable addressable capacity than the WD.
Buy Lexar drives, people.
It’s a good problem to have :slight_smile:
Thanks!!! Good info.
