Permission Denied Accessing a Docker Container Config
I am at my wits end with this. I need to edit the config file for nextcloud so that I can add my tailnet to trusted domains, but no matter what I try, I cannot access the config.php for nextcloud.
when I enter the path into the CLI i get “permission denied” and no matter which commands I use (chown / usermod / etc) to adjust permissions, I still get denied.
what am I missing?
Most likely you are trying to reach the file from the host at the wrong path, or the file lives inside the container/volume and not where you expect.
On ZimaOS, do not fight it with random chown or usermod first. Confirm where config.php actually is.
Try this:
docker ps --format "table {{.Names}}\t{{.Image}}"
Find your Nextcloud container name, then inspect its mounts:
docker inspect <nextcloud-container-name> --format '{{range .Mounts}}{{println .Source "->" .Destination}}{{end}}'
Then either:
Option 1, edit from the host
If you see a mount that maps to Nextcloud web data, check for:
find /DATA/AppData -path "*nextcloud*" -name config.php 2>/dev/null
Option 2, edit from inside the container
This is often the cleaner way:
docker exec -it <nextcloud-container-name> sh
find / -name config.php 2>/dev/null
In most Nextcloud containers the file ends up here:
/var/www/html/config/config.php
Then edit it from inside the container with whatever editor exists, or print it first:
cat /var/www/html/config/config.php
If the issue is just host permission denied, also check who owns the file from the host side before changing anything:
ls -l /full/path/to/config.php
ls -ld /full/path/to /full/path/to/config
What you are probably missing is this:
the file is either inside the container filesystem, or in a Docker-mounted path owned by root, so changing permissions on the wrong host folder will do nothing.
Post the output of these 3 commands and it will be much easier to tell you the exact path:
OK, I’ve gotten to here, with option 1 and 2;
@root:~ ➜ $ docker inspect nextcloud --format '{{range .Mounts}}{{println .Source "->" .Destination}}{{end}}'
WARNING: Error loading config file: open /DATA/.docker/config.json: permission denied
/DATA/AppData/nextcloud/var/www/html -> /var/www/html
@root:~ ➜ $ find /DATA/AppData -path "*nextcloud*" -name config.php 2>/dev/null
/DATA/AppData/nextcloud/var/www/html/config/config.php
@root:~ ➜ $ docker exec -it nextcloud sh
# find / -name config.php 2>/dev/null
And when I check who owns the file from the host side this is what is returned:
@root:~ ➜ $ ls -l /DATA/AppData/nextcloud/var/www/html/config/config.php
-rw-r----- 1 www-data www-data 812 Mar 20 17:57 /DATA/AppData/nextcloud/var/www/html/config/config.php
@root:~ ➜ $ ls -ld /DATA/AppData/nextcloud/var/www/html/config/config.php
from here i should be able to just enter
vim /var/www/html/config/config.php
right?
You’re very close, just one small misunderstanding.
That path:
only works inside the container, not from the host.
From your current position (host)
You need to use the full host path:
vim /DATA/AppData/nextcloud/var/www/html/config/config.php
OR inside the container (cleaner)
Since you already did:
Then run:
vi /var/www/html/config/config.php
Why you got stuck
  • File is owned by www-data
  • Permissions are 640
  • So only:
    • owner (www-data)
    • or root
      can edit it
You are root, so you’re fine — but only if you use the correct path.
Ignore this warning (not your issue)
That’s Docker CLI config, not Nextcloud, safe to ignore.
Bottom line
  • Host > use /DATA/AppData/...
  • Container > use /var/www/html/...
You are a beautiful human being, friend.
