If this also fails, then it would further suggest a DNS / network path issue.
Suggested adjustments
You could also try:
Temporarily setting DNS servers to something like 1.1.1.1 / 8.8.8.8
If running Pi-hole / AdGuard, allowing ghcr.io
Checking that no VPN / proxy is intercepting traffic
Why these steps
Paperless-NGX relies on several image pulls from GitHub Container Registry.
If DNS isn’t resolving properly, the installer may fail around ~80% as you saw.
Dear all,
on YT is a solution to change the “tika” version.
It will be a version from Apache.
Unfortunatly the video is in german.
keywords > Paperless NGX mit original apache/tika <
I hope it will be helpful for someone
from “image: ghcr.io/paperless-ngx/tika:latest”
to “image: docker.io/apache/tika:latest”
I’ve exracted the file from coolstore zip , change the line and try with this file a single app installation. The Installation goes to 100%, but after start it doesn’t work for me. I’m new to ZimaOS and the error messages are not understandable for me.
