I have installed ZIMAOS newest version. I am encountering package manager issue while trying to install packages via ssh.
I tried “apt install ”, “apt-get update”,“yum install ”. But issue not resolved.
Can anyone help if they same same issue?
ZimaOS consists of a fairly regular Linux and GNU software stack, built with Buildroot using Linux, the GNU C library, the systemd launch daemon, and the Docker container engine and KVM virtualization engine required by ZimaOS.
I have the same issue. I want to mount my cloud drive with davfs2, but there is no package manager available. (AList is not what I’m looking for since the files need to be accessible in the Files app, and it does not support webdav, only Dropbox, GDrive and OneDrive.)
You would like to mount a WebDAV resource, right?
Yes, I have a cloud provider who is not one of the standard three offered, and they have a WebDAV interface. Would be great to use that as one of my NAS locations.
Is this helpful?
No idea, I can’t read the language :-).
On my laptop I use Mountain Duck to mount cloud drives, I basically need that. Or what AList does but at the OS level so that it’s available to the whole ZimaBoard.
