OneDrive connection issue – login dialog closes immediately
Hello everyone,
I wanted to ask if anyone else in the community is experiencing a similar issue.
On my ZIMA installation I was initially able to successfully connect my Microsoft OneDrive account, and several backup jobs ran without any problems.
However, recently the connection stopped working. When I try to reconnect to OneDrive, the login dialog briefly opens but then immediately closes again before I can complete the authentication process.
Because of this, I’m currently unable to start any new backup jobs.
Has anyone encountered the same issue or found a possible solution?
Thanks in advance!
Exactly the same problems
Same symptom here. I dug into the backend logs and found the actual root
cause is AADSTS7000222 — IceWhale’s Azure app client_secret has expired
on Microsoft’s side, which fails the OAuth flow for everyone. Full
analysis with logs and suggested fixes here: Root cause: OneDrive integration broken globally — IceWhale's Azure client_secret has expired (AADSTS7000222)
