Obsidian Notes Setup Issues
Hello, just recently got the ZimaBlade and have been having a blast setting it up, I’ve run into an issue while trying to set up Obsidian, using the Links through the app store, I get an error unable to run, due to unsecure access.
So, I setup a reverse Proxy using ngix and was able to access it, but when I mounted a file so I could Import my vault, it never appeared in the designated folder I setup. As far as I can find, I couldn’t run a terminal in the selkies environment to try and find the files. Then I restarted the container and now selkies opens but Obsidian doesnt actually load up.
My plan is to redo the proxy setup, but I’m curious if others have to go through this arduous process for the application or maybe there is a simpler way to go about installing Obsidian and Importing a Markdown Vault.
