NVMevM.2 SSD stick not showing in web UI
Hey, guys - just noticed that the 2 TB SSD stick I have installed in slot A of my ZimaCube is not showing up in the web UI correctly like it has in the past. See pic attached. Dunno how long it has been this way. I have tried restarting the interface as well as restarting my Cube to no avail. Any advice?
TIA,
Pat
Hey, I will forward this issue to the team.
Can you execute the following three lines of commands and then send the results to us?
sudo -i
lspci
cat /etc/casaos/local-storage.conf
root@zimacube:/root ➜ # lspci
00:00.0 Host bridge: Intel Corporation Device 461c
00:02.0 VGA compatible controller: Intel Corporation Alder Lake-N [UHD Graphics]
00:0a.0 Signal processing controller: Intel Corporation Platform Monitoring Technology (rev 01)
00:14.0 USB controller: Intel Corporation Alder Lake-N PCH USB 3.2 xHCI Host Controller
00:14.2 RAM memory: Intel Corporation Alder Lake-N PCH Shared SRAM
00:16.0 Communication controller: Intel Corporation Alder Lake-N PCH HECI Controller
00:1a.0 SD Host controller: Intel Corporation Device 54c4
00:1c.0 PCI bridge: Intel Corporation Device 54b8
00:1c.6 PCI bridge: Intel Corporation Device 54be
00:1d.0 PCI bridge: Intel Corporation Alder Lake-N PCI Express Root Port
00:1d.2 PCI bridge: Intel Corporation Alder Lake-N PCI Express Root Port
00:1e.0 Communication controller: Intel Corporation Alder Lake-N Serial IO UART Host Controller
00:1e.3 Serial bus controller: Intel Corporation Device 54ab
00:1f.0 ISA bridge: Intel Corporation Alder Lake-N PCH eSPI Controller
00:1f.3 Audio device: Intel Corporation Alder Lake-N PCH High Definition Audio Controller
00:1f.4 SMBus: Intel Corporation Alder Lake-N SMBus
00:1f.5 Serial bus controller: Intel Corporation Alder Lake-N SPI (flash) Controller
01:00.0 PCI bridge: ASMedia Technology Inc. ASM2806 4-Port PCIe x2 Gen3 Packet Switch (rev 01)
02:00.0 PCI bridge: ASMedia Technology Inc. ASM2806 4-Port PCIe x2 Gen3 Packet Switch (rev 01)
02:02.0 PCI bridge: ASMedia Technology Inc. ASM2806 4-Port PCIe x2 Gen3 Packet Switch (rev 01)
02:06.0 PCI bridge: ASMedia Technology Inc. ASM2806 4-Port PCIe x2 Gen3 Packet Switch (rev 01)
02:0e.0 PCI bridge: ASMedia Technology Inc. ASM2806 4-Port PCIe x2 Gen3 Packet Switch (rev 01)
03:00.0 Ethernet controller: Intel Corporation Ethernet Controller I226-V (rev 04)
04:00.0 Ethernet controller: Intel Corporation Ethernet Controller I226-V (rev 04)
05:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. OM8PGP4 NVMe PCIe SSD (DRAM-less)
07:00.0 PCI bridge: ASMedia Technology Inc. ASM2806 4-Port PCIe x2 Gen3 Packet Switch (rev 01)
08:00.0 PCI bridge: ASMedia Technology Inc. ASM2806 4-Port PCIe x2 Gen3 Packet Switch (rev 01)
08:02.0 PCI bridge: ASMedia Technology Inc. ASM2806 4-Port PCIe x2 Gen3 Packet Switch (rev 01)
08:06.0 PCI bridge: ASMedia Technology Inc. ASM2806 4-Port PCIe x2 Gen3 Packet Switch (rev 01)
08:0e.0 PCI bridge: ASMedia Technology Inc. ASM2806 4-Port PCIe x2 Gen3 Packet Switch (rev 01)
09:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller S4LV008[Pascal]
0d:00.0 SATA controller: ASMedia Technology Inc. ASM1166 Serial ATA Controller (rev 02)
0e:00.0 3D controller: NVIDIA Corporation GP104GL [Tesla P4] (rev a1)
root@zimacube:/root ➜ # cat /etc/casaos/local-storage.conf
[common]
RuntimePath = /var/run/casaos
[app]
LogPath = /var/log/casaos
LogSaveName = local-storage
LogFileExt = log
DBPath = /var/lib/casaos/db
ShellPath = /usr/share/casaos/shell
[server]
USBAutoMount = True
EnableMergerFS = false
SataStartNumber = 0
NVME = 09:00.0,0a:00.0,0b:00.0,0c:00.0
DiskSleepWaitTime = 242
thank you !
Pat
Need to execute the following command
vi /etc/casaos/local-storage.conf
Then delete the NVME line, and after the deletion is complete, this paragraph should look like this
[server]
USBAutoMount = True
SataStartNumber = 0
Finally restart the service
systemctl restart zimaos-local-storage.service
Thank you, @Zima-Dina! That fixed the issue. You guys rock.
Pat
