NVIDIA-container-runtime
6.8 0.6 3.82G 88.8M 9760 root 02:38:16 73 0 S 0 0 dockerd --host=fd:// --add-runtime=nvidia=/usr/bin/nvidia-container-runtime
Is there a way to stop above process on my ZImaOS server, I don’t have Nvida GPU, but this run in the background using CPU and causing iowait error along with python.
2026-04-15 21:18:41(+0100) (00:01:28) CRITICAL on CPU_IOWAIT(84.6): dockerd, python3.12, containerd
2026-04-15 21:18:29(+0100) (00:00:06) WARNING on CPU_TOTAL(75)
2026-04-15 21:18:11(+0100) (00:00:06) CRITICAL on CPU_IOWAIT(36): python3, dockerd, python3.12
Also python seems to be a bit old? Should this be updated to 3.14 or 3.15?
That dockerd --add-runtime=nvidia=... line is just Docker being started with optional NVIDIA support, it’s not actually using GPU or causing load by itself.
The real issue is your iowait , that usually means a container (likely the Python one) is hammering disk I/O, not the NVIDIA runtime.
I’d check what’s running first:
docker ps
docker stats
Also wouldn’t touch system Python, ZimaOS manages that.
If you share those outputs, we can pinpoint exactly what’s causing it
Code below, but I recon it has stopped now, removed some bits I was testing (wazuh, netdata)
CONTAINER ID   IMAGE        COMMAND                  CREATED        STATUS        NAMES
a17ab625e1c1   ghcr.io/immich-app/immich-server:release                                                          "tini -- /bin/bash -…"   28 hours ago   Up 27 hours (healthy)        immich-server
fa01472594e7   ghcr.io/immich-app/immich-machine-learning:commit-5aece8321209fc9d29ed1e3680f5611954873be6-rocm   "tini -- python -m i…"   28 hours ago   Up 27 hours (healthy)        immich-machine-learning
dbd0c6e750d5   amir20/dozzle:latest        "/dozzle"                33 hours ago   Up 33 hours        dozzle
64a110c51f50   tailscale/tailscale:latest        "/bin/sh -c 'tailsca…"   33 hours ago   Up 33 hours        tailscale
ccb7b92c0cb4   ghcr.io/immich-app/postgres:14-vectorchord0.3.0-pgvectors0.2.0                                    "/usr/local/bin/immi…"   33 hours ago   Up 27 hours (healthy)        immich-postgres
633f2fb5552b   redis:6.2.20-alpine        "docker-entrypoint.s…"   33 hours ago   Up 27 hours        immich-redis
397f55272f9d   syncthing/syncthing:latest        "/bin/entrypoint.sh …"   3 days ago     Up 33 hours (healthy)      																						big-bear-syncthing
4201192d5edd   ghcr.io/alexta69/metube:latest        "/usr/bin/tini -g --…"   3 days ago     Up 33 hours (healthy)        metube
ad4f24a17546   linuxserver/jellyfin:latest        "/init"                  4 days ago     Up 33 hours                      																					jellyfin
0c3b27d09608   vaultwarden/server:latest        "/start.sh"              4 days ago     Up 33 hours (healthy)        vaultwarden
3b9e3aa67827   ugeek/webdav:amd64        "/bin/sh -c '/entryp…"   5 days ago     Up 33 hours        webdav
cb4f5b048a52   triliumnext/trilium:v0.102.2        "docker-entrypoint.s…"   7 days ago     Up 33 hours (healthy)        big-bear-trilium
2bf3df769ac1   nicolargo/glances:4.5.3.2-full        "/bin/sh -c '/venv/b…"   2 weeks ago    Up 33 hours        big-bear-glances
c7077af02756   openspeedtest/latest:latest        "/docker-entrypoint.…"   2 weeks ago    Up 33 hours        openspeedtest
7f31c984e0c0   onlyoffice/documentserver:9.3.1        "/app/ds/run-documen…"   2 weeks ago    Up 33 hours        documentserver
62c2aae2f3ac   misterbabou/gptwol:latest        "/usr/local/bin/dock…"   3 weeks ago    Up 33 hours        gptwol
88a500dd834a   wisdomsky/cloudflared-web:latest        "/bin/sh -c 'node /v…"   4 weeks ago    Up 33 hours        big-bear-cloudflared-web
cc1c480e4838   ghcr.io/advplyr/audiobookshelf:latest                                                             "tini -- node index.…"   4 weeks ago    Up 33 hours        big-bear-audiobookshelf
d06112c216a0   jvmilazz0/kavita:0.8.8        "/bin/bash /entrypoi…"   4 weeks ago    Up 33 hours (healthy)        kavita
5723fc25de2e   registry.gitlab.com/storyteller-platform/storyteller:web-v2.6.0-experimental.14                   "/usr/bin/tini -- no…"   4 weeks ago    Up 33 hours        big-bear-storyteller
e2a3593f0d7a   700a039fdd8a        "/usr/bin/entrypoint…"   6 weeks ago    Up 33 hours (healthy)        big-bear-owncloud
2b9bc3f3177c   redis:6.2.20        "docker-entrypoint.s…"   6 weeks ago    Up 33 hours (healthy)        big-bear-owncloud-redis
bfe321f8f160   eb40c69647cc        "docker-entrypoint.s…"   6 weeks ago    Up 33 hours (healthy)        big-bear-owncloud-db
1741cda58d1c   893f81d622eb        "sh ./scripts/docker…"   2 months ago   Up 33 hours (healthy)        pingvin-share-pingvin-share-1
2c8dec4fe205   ghcr.io/dockpeek/dockpeek:v1.7.2        "gunicorn -c gunicor…"   2 months ago   Up 33 hours (healthy)        big-bear-dockpeek
88dc526de27e   louislam/uptime-kuma:latest        "/usr/bin/dumb-init …"   2 months ago   Up 33 hours (healthy)        uptime-kuma
d9c7eb7967c4   ghcr.io/swingmx/swingmusic:latest        "python -m swingmusi…"   2 months ago   Up 33 hours        swingmusic
CONTAINER ID   NAME                            CPU %     MEM USAGE / LIMIT     MEM %     NET I/O           BLOCK I/O         PIDS
a17ab625e1c1   immich-server                   0.13%     1.014GiB / 15.41GiB   6.58%     1.25GB / 2.32GB   102GB / 1.64GB    24
fa01472594e7   immich-machine-learning         18.83%    234.5MiB / 15.41GiB   1.49%     7.18MB / 3.22MB   881MB / 0B        12
dbd0c6e750d5   dozzle                          0.40%     15.02MiB / 15.41GiB   0.10%     651kB / 1.27MB    164kB / 0B        11
64a110c51f50   tailscale                       0.27%     24.11MiB / 15.41GiB   0.15%     0B / 0B           336kB / 9.92MB    20
ccb7b92c0cb4   immich-postgres                 0.01%     459.6MiB / 15.41GiB   2.91%     320MB / 871MB     283MB / 1.56GB    19
633f2fb5552b   immich-redis                    0.26%     8.727MiB / 15.41GiB   0.06%     509MB / 129MB     4.42MB / 424MB    5
397f55272f9d   big-bear-syncthing              0.11%     38.47MiB / 15.41GiB   0.24%     67.1MB / 69.7MB   34.8MB / 1.09MB   22
4201192d5edd   metube                          0.01%     98.18MiB / 15.41GiB   0.62%     1.28MB / 980kB    79.8MB / 4.1kB    9
ad4f24a17546   jellyfin                        0.00%     641.1MiB / 15.41GiB   4.06%     1.95MB / 14.2MB   393MB / 1.26GB    40
0c3b27d09608   vaultwarden                     0.00%     21.59MiB / 15.41GiB   0.14%     514kB / 3.45MB    46.7MB / 258kB    13
3b9e3aa67827   webdav                          0.00%     62.73MiB / 15.41GiB   0.40%     168MB / 5.42GB    306MB / 293MB     6
cb4f5b048a52   big-bear-trilium                0.00%     157.5MiB / 15.41GiB   1.00%     5.59MB / 12.8MB   139MB / 134MB     11
2bf3df769ac1   big-bear-glances                1.44%     100.4MiB / 15.41GiB   0.64%     1.96MB / 11.7MB   70.5MB / 4.1kB    32
c7077af02756   openspeedtest                   0.00%     7.41MiB / 15.41GiB    0.05%     872kB / 0B        6.98MB / 12.3kB   8
7f31c984e0c0   documentserver                  0.28%     692.1MiB / 15.41GiB   4.39%     1.28MB / 94.1kB   1.38GB / 293MB    69
62c2aae2f3ac   gptwol                          0.02%     76.78MiB / 15.41GiB   0.49%     0B / 0B           46.5MB / 0B       5
88a500dd834a   big-bear-cloudflared-web        0.51%     48.32MiB / 15.41GiB   0.31%     0B / 0B           85.5MB / 0B       18
cc1c480e4838   big-bear-audiobookshelf         0.03%     49.98MiB / 15.41GiB   0.32%     855kB / 0B        74.2MB / 639kB    12
d06112c216a0   kavita                          0.62%     307.7MiB / 15.41GiB   1.95%     613kB / 30.2kB    173MB / 1.76MB    52
5723fc25de2e   big-bear-storyteller            0.01%     559.2MiB / 15.41GiB   3.54%     495kB / 0B        212MB / 2.55MB    21
e2a3593f0d7a   big-bear-owncloud               0.01%     168.6MiB / 15.41GiB   1.07%     125MB / 59.3MB    144MB / 48.9MB    10
2b9bc3f3177c   big-bear-owncloud-redis         3.20%     4.234MiB / 15.41GiB   0.03%     10.2MB / 5.86MB   13.9MB / 1.26MB   5
bfe321f8f160   big-bear-owncloud-db            2.73%     91.5MiB / 15.41GiB    0.58%     50.6MB / 118MB    55.7MB / 586MB    11
1741cda58d1c   pingvin-share-pingvin-share-1   3.45%     159.9MiB / 15.41GiB   1.01%     763kB / 4.42kB    225MB / 5.38MB    48
2c8dec4fe205   big-bear-dockpeek               0.08%     85.62MiB / 15.41GiB   0.54%     967kB / 72.9kB    48.4MB / 0B       3
88dc526de27e   uptime-kuma                     0.78%     127.5MiB / 15.41GiB   0.81%     1.69MB / 91.9kB   92.1MB / 2.48MB   19
d9c7eb7967c4   swingmusic                      0.08%     68.08MiB / 15.41GiB   0.43%     764kB / 0B        63.5MB / 28.7kB   2
That NVIDIA runtime isn’t your issue.
From your stats, it’s immich-machine-learning pulling ~19% CPU and doing constant processing, that’s what’s causing the iowait.
If you stop it and the load drops, you’ve found the cause.
