Hi, I’m configuring nginx and my question is:
It conflicts with Zimaos over port 80/443. Can these be changed without affecting the system? (In my opinion, this would be the simplest option, but I’ll ask first.)
If I change them, I set the device (for example) to 8080/8443 and the container to 8081/8444.
Does this work correctly?
It’s literally what’s giving me the most trouble to get it working 100% immich
thx
I had the same problem. I set ZimaOS to use port 85 with no issues. Let nginx have 80/443.
So what ports did you set for Zimaos (Immich stopped working for me, and I had to reinstall everything, and just in case, this was my mistake)
I set port 90/444 for Zimas and 80/443 for Ngnix, and it worked pretty well.
Did you do the same? (Different ports)
Nothing stays blocked for me, nginx stays blocked for a while and I have also changed the system ports…
Is this post helpful?
no sry
