Good question and yes, this is mostly by design, not a mistake on your part.
Short answer: containers separate apps, not storage.
What’s happening is:
- Nextcloud (the app) runs inside a container
- Your storage pool is mounted into the container as a volume
- So from the OS point of view they’re separate, but from inside Nextcloud it looks like “part of the system”
This is normal Docker behavior and not a ZimaOS limitation.
What you can do (and what most people do):
- Keep Nextcloud app data (config, database, cache) in
/DATA/AppData/nextcloud - Point Nextcloud user data to a dedicated subfolder in your pool, e.g.
/DATA/NextcloudData
That keeps things clean and makes backups, restores, or even replacing Nextcloud much easier.
So:
- Containers stay isolated
- Your storage pool stays shared
- Data ownership and structure are still fully under your control
ZimaOS is handling this the right way, it gives you separation where it matters (apps), without locking your data away.
