Hello everyone! To better serve you and optimize our driver support, we are conducting a survey to learn about the network card models you are currently using. Whether it’s a PCIe or USB network card, please leave your model number in the comment section. We will update and upload the corresponding drivers on zimaos based on the information you provide, to enhance your user experience. Thank you for your participation and support! We look forward to your active responses.
I have an iMac Apple Airport as pciE-Express Wifi-Card because the machine was once upon a time a Hackintosh and for some reason the card worked OOB the first time I used some alpha of ZimaOS, I doubt this was intentional because these drivers are not open source (broadcom). Is ZimaOS running on freebsd or similar or a modified version of some small Linux distro? I can’t figure out how to do anything on that level myself since then. Aside from that it’s the one onboard on an (back when it was new) expensive ASUS H97-mainboard nothing out of the ordinary in that regard.
i have a dual card Ethernet Controller 10-Gigabit X540-AT2 it see by zimaos but does not work
howe can i optimize the drivers
Realtek wifi6 card RTL8852BE :
*-network UNCLAIMED
description: Network controller
product: RTL8852BE PCIe 802.11ax Wireless Network Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress cap_list
configuration: latency=0
resources: ioport:3000(size=256) memory:80700000-807fffff
Thanks
