Hi everyone, I need some help with deploying my own app to ZimaOS.
I created a simple website that I want to deploy to ZimaOS for our household usage, I containerized the app and can run it with docker compose locally.
However on ZimaOS, trying to run docker compose does not work
sige@ZimaOS:~/own_app/weather ➜ $ sudo docker compose up`
`Password:`
`mkdir /root/.docker: read-only file system
I also tried building the image locally, upload the image to ZimaOS and tried to use the UI to start the app.
However, the UI cannot find the local image, failed to pull.
Would really appreciate your opinion.
