Need help to install "Invoice Ninja" in zimaos
Hello friends,
I was trying to install “Invoice Ninja” in zimaboard2. The available Invoice Ninja app in zimaos app store is installable but it doesn’t work. I tried changing host side port. But no success. I would really appreciate if someone can guide on the installation process (through app store).
Thanks in advance
What happens exactly when you try and install it? Have you tried doing a custom install?
I tried both default install and custom install with host side port changed to a free port. But app does not start after installation. Do I need to change/add anything in custom install (eg. Environment Variable etc)
Use my docker-compose and follow the Instructions - tested and verified on ZimaOS 1.70 beta 1
https://github.com/chicohaager/zimapp/blob/main/invoiceninja.yml
Thank you very much. I will try it
