My ZimaClient not working
My ZimaClient has been operating normally until I updated my MacOS to the latest version. Then my ZimaClient had a problem and I could no longer access Dashborad, but I could still connect to the hard disk space through ThunderBolt. Does anyone have any solution? Thanks
我的ZimaClient運作一直很正常,直到我的MacOS更新到了最新的版本後,我的ZimaClient就出現問題了,無法再去訪問Dashborad,但我依舊可以透過ThunderBolt 連結到硬碟空間。請問有任何朋友有方法解決嗎?謝謝
Add images
截圖 2025-01-06 晚上11.06.41
Hi, recently we have published a new beta ZimaClient, it has new UI and more stable than before,Would you like to try it? Click here to download the latest version: Zima Client - Google Drive
Thank you for your reply, but I am currently using an iMac 5k with Intel CPU. Is there a version suitable for this version? Thanks
Sorry, this version may take a while, we are preparing it, and I will let you know any progress as soon as possible!
I used my Mac air m2 to install a new ZimaClient. I can log in to ZimaOS, but I found that Zimacube cannot connect to the Internet . Is there any way to solve it? Thanks
Can you take a screenshot? When you say you can’t connect to the Internet, do you mean that there is no network on zimacube when the network cable is plugged in?
https://zima-client.r2.icewhale.io/v2/mac/x64/Zima-2.0.0-beta.3-mac-x64.dmg Can you try it?
yes~ There is no network on Zimacube.I can’t download anything from the app store. Thanks
After I updated to 1.31, my GPU has been stuck at 17%. Is this normal?
截圖 2025-01-10 晚上11.41.36
I can log in now, thank you, but I still don’t know why my zimacube can’t connect to the Internet.
截圖 2025-01-11 凌晨12.06.06
块引用 https://zima-client.r2.icewhale.io/v2/mac/x64/Zima-2.0.0-beta.3-mac-x64.dmg Can you try it?
截圖 2025-01-11 晚上9.05.05
I don’t know why I can’t log in again. I feel like there are a lot of problems after updating to 1.31.
Try the new version: Zima Client - Google Drive
It seems you have connected to ZimaCube by thunderbolt, which give you the ability to sharing files between ZimaOS and you computer.
When you want download apps for you computer, you need an Internet connection for your computer. It may be a Wi-Fi or something for you computer.
When you want download apps for you ZimaCube, you need an Internet connection for your ZimaCube. For example, a ether cable that connects to your router is a good option.
The thunderbolt connection does’t provide Internet access by default.
Hope this helpful.
Thank you for your reply. My Zimacube was working fine, and there was no problem connecting to Thunderbolt and the network. But after updating to 1.31 and macOS, problems started to occur. The Zima Client issue has been resolved, but now I can’t connect to the Internet. Thank you.
After updating this version, the network can be connected~~~Thanks
I had the issue with the ZimaClient stuck at “Initializing” and the beta client worked great. First time use of ZimaCube and was disappointed with the hanging client but this post was the solution. Glad to have found it and THANKS!
This is our latest version, if you have any further questions, please feel free to contact us.
