I have a new mini pc with a Mediatek MT7920 wifi/bt card installed that I cant get to work.
nmcli radio wifi shows “enabled”
lspci | grep -i network shows “03:00.0 Network controller: MEDIATEK Corp. Device 7920”
Using lspci these are my controllers:
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller [10ec:8125] (rev 0c)
03:00.0 Network controller [0280]: MEDIATEK Corp. Device [14c3:7920]
The Ethernet shos as 1 gpbs in the UI but maybe thats just because of the router having that speed?
It shows up in the UI as a port under network section.
And I could find it nmcli device
nmtui just cant find it
What to do?
A lot of the newer MediaTek WiFi chipsets are still a bit hit-and-miss under Linux depending on the kernel version and firmware included in the OS. Since ZimaOS is Buildroot-based and fairly stripped down, it’s possible the MT7920 firmware or driver support simply isn’t included yet.
The fact that:
nmcli radio wifi = enabled
lspci detects the MT7920
nmcli device can see something
Is actually a good sign. It usually means PCI detection is working, but the wireless interface itself is not fully initializing.
I’d avoid changing anything destructive for now and first confirm whether the driver actually loaded correctly.
Can you post the output of these commands:
lspci -nnk | grep -A3 7920
ip link
dmesg | grep -i mt79
dmesg | grep -i firmware
The important part is whether the kernel attached the mt7921e driver (MediaTek often uses the same driver family for MT7920/7921 variants) and whether firmware loading failed.
Also worth mentioning:
ZimaOS 1.6.x has had a few networking oddities already
Some mini PCs ship very new WiFi chip revisions requiring newer Linux firmware packages
Ethernet showing 1Gbps is normal if your router/switch port is only negotiating at 1Gbps, even though the RTL8125 itself is 2.5Gb capable
So at the moment this still looks more like missing firmware/driver support than hardware failure.
Subsystem: AzureWave Device [1a3b:6471]
Kernel driver in use: mt7921e
Kernel modules: mt7921e
root@ZimaOS:/root ➜ # ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether 78:55:36:03:af:e9 brd ff:ff:ff:ff:ff:ff
altname eno1
altname enp2s0
3: virbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default qlen 1000
link/ether 52:54:00:e4:d5:fa brd ff:ff:ff:ff:ff:ff
4: ztjljn3e3a: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 2800 qdisc fq_codel state UNKNOWN mode DEFAULT group default qlen 1000
link/ether 82:d9:e6:e9:00:e9 brd ff:ff:ff:ff:ff:ff
5: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default
link/ether 02:42:4b:d2:08:3c brd ff:ff:ff:ff:ff:ff
root@ZimaOS:/root ➜ # dmesg | grep -i mt79
[ 5.157094] mt7921e 0000:03:00.0: enabling device (0000 -> 0002)
[ 5.157583] mt7921e 0000:03:00.0: Direct firmware load for mediatek/WIFI_RAM_CODE_MT7961_1a.bin failed with error -2
[ 5.160776] mt7921e 0000:03:00.0: ASIC revision: 79200010
[ 5.235935] mt7921e 0000:03:00.0: Direct firmware load for mediatek/WIFI_MT7961_patch_mcu_1a_2_hdr.bin failed with error -2
[ 5.310709] mt7921e 0000:03:00.0: Direct firmware load for mediatek/WIFI_MT7961_patch_mcu_1a_2_hdr.bin failed with error -2
[ 5.385128] mt7921e 0000:03:00.0: Direct firmware load for mediatek/WIFI_MT7961_patch_mcu_1a_2_hdr.bin failed with error -2
[ 5.459121] mt7921e 0000:03:00.0: Direct firmware load for mediatek/WIFI_MT7961_patch_mcu_1a_2_hdr.bin failed with error -2
[ 5.534168] mt7921e 0000:03:00.0: Direct firmware load for mediatek/WIFI_MT7961_patch_mcu_1a_2_hdr.bin failed with error -2
[ 5.607846] mt7921e 0000:03:00.0: Direct firmware load for mediatek/WIFI_MT7961_patch_mcu_1a_2_hdr.bin failed with error -2
[ 5.681312] mt7921e 0000:03:00.0: Direct firmware load for mediatek/WIFI_MT7961_patch_mcu_1a_2_hdr.bin failed with error -2
[ 5.755267] mt7921e 0000:03:00.0: Direct firmware load for mediatek/WIFI_MT7961_patch_mcu_1a_2_hdr.bin failed with error -2
[ 5.846958] mt7921e 0000:03:00.0: Direct firmware load for mediatek/WIFI_MT7961_patch_mcu_1a_2_hdr.bin failed with error -2
[ 5.919959] mt7921e 0000:03:00.0: Direct firmware load for mediatek/WIFI_MT7961_patch_mcu_1a_2_hdr.bin failed with error -2
[ 5.991113] mt7921e 0000:03:00.0: hardware init failed
root@ZimaOS:/root ➜ # dmesg | grep -i firmware
[ 0.168600] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 5.141545] [drm] Loading DMUB firmware via PSP: version=0x04000045
[ 5.142032] [drm] Found VCN firmware Version ENC: 1.32 DEC: 4 VEP: 0 Revision: 0
So some kind of firmware problem?
Yep, that explains it.
The good news is your MT7920 isn’t dead and the driver is actually loading correctly:
The problem is that the firmware files the driver needs are missing:
The -2 error simply means “file not found”. Because those firmware files aren’t available, the card can’t complete its hardware initialization and Wi-Fi never comes online.
So this looks less like a hardware issue and more like a missing firmware package in ZimaOS. The logs are pretty clear:
• Card detected successfully
• Driver loaded successfully
• Firmware files missing
• Hardware initialization failed
• No Wi-Fi interface created
I’d say this is something the IceWhale team should look at, as support for the MT7920 appears to be partially present but the required MediaTek firmware blobs are missing from the OS image.
djmiek
May 25, 2026, 12:55pm
5
@Zima-Giorgio
Can you guys have a look at this? Or know if there is some work around?
djmiek
July 22, 2026, 10:04pm
6
Do you think the new 1.7 release with updated kernels and stuff could fix this issue?
Yes, updating to ZimaOS 1.7.0 should very likely fix this issue.
Your logs show that the mt7921e driver is already loading correctly, but initialization fails because these firmware files are missing:
ZimaOS 1.7.0 now includes these MT7920 firmware files. Please update to 1.7.0 and perform reboot.
I have now verified this directly on my ZimaCube running ZimaOS 1.7.0-beta1.
Both required MT7920 firmware files are included:
/lib/firmware/mediatek/WIFI_RAM_CODE_MT7961_1a.bin
/lib/firmware/mediatek/WIFI_MT7961_patch_mcu_1a_2_hdr.bin
djmiek, updating to 1.7.0 and rebooting should resolve the original error -2 missing-firmware failure.
We still need your result after updating before confirming the MT7920 fully initialises on your hardware.
djmiek
July 24, 2026, 8:31am
9
I am a little scared to go from stable to beta so might wait for the official 1.7 release.
djmiek
August 16, 2026, 8:25pm
10
I am know running 1.7 and I can donfirm it now works and I am now connected to my network using WiFi
