Is there a way to enable multi NIC support for VMs running in ZVM? If not, are there plans to support?
Sorry, not yet. Can you tell me why you want it? So that I can better understand and report this requirement to the product manager! Thanks!
Thanks for the quick response. I am looking to test various IDS and SIEM software and using virtual machines is quite convenient. Support for multiple NICs would be extremely helpful. Would prefer to continue testing ZimaOS on the cube rather than using Proxmox.
Sounds great! I will give feedback to the product manager as soon as possible. I am sorry that we are a small team and cannot meet all your needs at the first time, but we will speed up. Thank you very much for your suggestions. I will let you know if there are any updates.
Hello, greetings from Germany.
Im also interested on this feature. because i plan to by me the ZimaCube Pro later this year. I will use the 2x 2.5 GB Nics on ZVM for virtualize opnsense Firewall Server. So i can use only One Device for all Jobs
Same here. I really hope it’s coming soon.
Could you please elaborate on the specific scenarios or requirements you would like to realize with this feature? We attach great importance to every request, and understanding your core requirements will help us to more accurately develop optimization solutions.
I would like to run my router (i.e. OPNsense) in ZVM
Being able to use 2 nics would be great. Very much the same idea MonkeyOnKeyboard expressed in the comment before mine
Thx in advance
Hi,
I was also looking to implement OPNSense as a VM on ZimaOS.
I hope multi NIC support is implmented before I get my Zimaboard 2.
