Migrating an existing btrfs RAID5 into ZimaOS without reformatting (findings)
I’ve been experimenting with migrating an existing RAID5 volume into ZimaOS and wanted to share what I found in case it’s useful to others or the devs.
Hardware
  • ASUSTOR AS5404T
  • Existing RAID5
  • btrfs
  • 4 TB usable
  • Migrated drives directly into a ZimaBlade/ZimaOS installation
What worked
The RAID assembles correctly:
/dev/md127
The filesystem is healthy.
The data is intact.
The base subvolume contains all user data.
Mounting:
mount -t btrfs -o subvol=base /dev/md127 /media/asustor
works perfectly.
The Files application can browse everything normally.
Storage statistics also report correctly:
  • ~3.99 TB
  • ~970 GB used
What didn’t work
Out of the box, ZimaOS couldn’t discover the existing volume correctly.
The Files app originally reported:
The target path is unavailable because its storage is not mounted.
The RAID also appeared in Settings as:
RAID5 Missed
even though:
  • mdadm reports the array healthy
  • Btrfs is healthy
  • all data is accessible
What I had to change
I updated the local-storage database so the RAID mount point matched the mounted filesystem.
I then mounted the Btrfs base subvolume and restarted the storage/files services.
After that:
  • Files works correctly
  • Storage capacity is reported correctly
  • Existing data is accessible
The only remaining issue is that Settings still reports “RAID5 Missed”, even though the array is functioning normally.
The API currently reports:
devices: []
raid_status: "urge"
which seems to be what drives the warning.
Question
Is native support for importing existing ASUSTOR Btrfs RAID arrays planned?
It feels like ZimaOS is already 95% of the way there—the remaining issue appears to be RAID discovery/metadata rather than filesystem compatibility.
Well you kind of mixing two different RAID 5/6 types since Btrfs is virtual media.
That is why mdadm reports no volumes because you don’t have physical partitions in an array and only virtual software ones from Btrfs.
Hey thanks for taking a look. I may not have explained the original layout clearly. This array was created by asustor adm and is an mdadm raid5 with a btrfs filesystem on top.
mdadm --detail /dev/md125 reports:
  • RAID5
  • 3 active devices
  • clean state
  • MD_NAME=Delphi:1
I can mount the btrfs base subvolume manually and all data is intact so the filesystem itself appears healthy.
The issue seems to be that zima isn’t recognizing or assembling the existing array the same way adm did, so its storage service marks the raid as missing. Have you seen zima os successfully import an existing asustor mdadm+btrfs array without reformatting?
unfortunately its a linux mdadm issue and not specifically to ZimaOS.
mdadm looks for the descriptors in the physical volume then it scans in logical volumes.
But you have to mount it using a logical volume since the raid is not mapped on the physical gpt or mbr partition.
What I understand is that ASUSTOR NAS devices don’t make a true Linux RAID. That is why most will rebuild a new raid 5 with mdadm or will ignore this error since you can mount the btrfs snap shot. So its really your choice.
However, I would just dump the data over to a usb drive temporary and wipe and build the raid5 set with linux mdadm in ZimaOS then format the raid5 to btrfs and copy back the data to get rid of the error and be able to add drives because that is the only downside I see that it will not be able to add drives since they are not part of the file system snap shot that is getting mounted.
