【Made With IceWhale Community】 Garandil 's ZimaCube Thermal Testing
2 passes with utility stress. 1st pass is to heatsoak the cooling with the actual testing following right behind. During the run, the top temperature was measured at 81C on the CPU package, the chassis remained cool to the touch.
Garandil did run several iterations of the thermal testing, forcing the N100 package to run at 100% and the average peak temperature observed was 78C. In total, 10 tests have been run with the same pattern as in the video.
